1 - 10 of 10 Posts
92 4x4 rust bucket
ok guys, im pretty sure that this question hasnt come up after a quick scanning of this subforum....but im curious if i can fit a 2nd gen bed on my 1st gen ext. cab (1992), and if so would it also have to come off of an ext. cab 2nd gen?...
i saw what you did there!
yes you can and use a tape measure to see if same wheel base
and ext cab wheel base would be same as long bed reg cab wheel base
short bed reg cab be alone by itself unique
all ext cab should be short bed and therefore same as reg cab long bed
there may be an exception or special order though.,.,
Premium Member
woah there killer, wrong info.
Reg Cab Short Bed and Extended Cab beds are the same.. 6 ft bed.
Reg Cab Long Bed is the unique one. (8 ft bed I believe)
Then there's the Crew Cab bed.. which is 4 ft????
Heavy Metal Body Man
yup, crew cab is 4 ft, short bed is 6 ft, long bed is 8 ft
92 4x4 rust bucket
thanks guys...now i just gotta find a 6' 2nd gen bed in decent condition...pull a part was a waste of time...
just out of curiosity, have you ever seen a 2nd gen bed on a first gen truck? cause it looks terrible...
92 4x4 rust bucket
no i havent...ive seen newer full size beds on square body c/k trucks and thought those looked pretty good...so figured it would just translate to a smaller size...but does it really look super bad?...mostly i just cant find a 1st gen bed in decent condition and figure ill have a better chance finding a 2nd gen it good condition....
heres one of a stepside
fleetside
hideous if you ask me... half the truck is round, and the other half is square, it just doesnt work
sleeper
i was thinkin about that idea, but i just kept lookin and found a nice bed on craiglist, just be patient there out there.
Awww..you ain't got shit!
Gm did that from the factory on the 73-87 full size body style...Thought it was ugly. I think it looks better on this one, but the one grip I have is that the bed is actually slightly shorter on the newer trucks because of the bump on the back of the cab of the newer trucks. The gap is just too wide between the body of the 1st gen body and the 2nd gen bed. No if you scooted it up a fuzz it might look better. I don't think a fleetside bed would look get at all because of the lines.
1 - 10 of 10 Posts
