i recently put four inch blocks on the back of my s10 to fill the wheel well. 6/7 drop well the frame was bottoming out on the diff so i put some air in my air shocks. then today at the gas station i noticied the stupid chevy lean struck again. i let all the air out of the shocks and corrected it but im not sure how bad that is but just wanted to say that thanks
belltech makes a spring spacer to put above the coil but its a little too thick. you could put some 1/8" plate above the driver side coil spring(it needs to be a ring the same diameter as the spring) and it should level it out....if it is that annoying to you.
yeah it still hasnt come back i guess. but im thinking im going to c notch it just to get some metal working skills
Thanks For Your Support
A front lean does effect the rear to. Just not as much. Don't do the end link cover-up. Fix it.
Bring back *DARK STYLE*
That is true, but to fix the problem just use the spacer.
is dekitted...
pics of the truck w/ the 6/7?
