Got an update pic to show off..
Did you plasti dip the wheels or paint them. They look great with your Blazer
Stock column and guages are going to get VERY hard, it would be easier to use the stock block and MS the engine at that point, but I don't know if you could talk the MS into running the VVT. The column might be able to be bypassed with an alarm to trick the passlock system, but the gauges on all these new trucks are stepper motors run right off the ECM, so at best, with a full second compliment of sensors, you wouldn't have any of the idiot lights.I am interested in that swap, would love more info on how you fit that atlas I5 in the engine bay. I would love to do something like that without changing the cluster an steering column, and retain AC (too hot here to go without it). And what rear end, gear ratio and tranny do uypu have in there... The pics are great, your work looks amazing, but we need some specifics man!!!
they will be painted, as you can’t heat up convo-pros as the seal in between the two wheel halves will separate and cause an air leak. The front wheel has ‘black’ over the front wheel to darken it done in photoshop. It actually is a stock polished alum convo pro wheel on the front. The rear wheel in the phot is the actual rear wheel from the very first picture in this thread, just painted black. The tires are 14 years old, dry rotted, and have been fun doing burnouts with. The truck is currently sitting at a friend’s shop about to start the rear back-half, which then will have 15x15 in rear black painted convo pros..Did you plasti dip the wheels or paint them. They look great with your Blazer
..answer belowI am interested in that swap, would love more info on how you fit that atlas I5 in the engine bay. I would love to do something like that without changing the cluster an steering column, and retain AC (too hot here to go without it). And what rear end, gear ratio and tranny do uypu have in there... The pics are great, your work looks amazing, but we need some specifics man!!!
…what he said.Stock column and guages are going to get VERY hard, it would be easier to use the stock block and MS the engine at that point, but I don't know if you could talk the MS into running the VVT. The column might be able to be bypassed with an alarm to trick the passlock system, but the gauges on all these new trucks are stepper motors run right off the ECM, so at best, with a full second compliment of sensors, you wouldn't have any of the idiot lights.
…what I did was found a wrecked Colorado. I took everything from it, Steering column, gas pedal (drive by wire) full front to rear (head light to taillights) wire harness, gauge cluster, engine, trans, driveline, computers, dash, air conditioning/heater box (mounts to firewall) fuel lines, fuel tank and I think that’s about it.I am interested in that swap, would love more info on how you fit that atlas I5 in the engine bay….
Truck is far from done….June/july is the time period to go under the knife and get the rear tubbed
Pile of work.. lol I like that term. I usually call all cars turds.One awesome pile of work ! Looks great
So did the Afghan trip get cancelled, then? Or did the wife let you know they arrived, and are waiting for your return?
Man, I can't believe that I am saying this, but I really like your Blazer. This is coming from someone who has a blind burning hatred of flame paint schemes. But I dig your's.
thanks for the words! As far as I know im the only person who has put an i5 into an s10. I know I have helped another guy who is putting one into a jeep, but he is still collecting parts. And yes the flames I wanted something easy and simple, some people go overboard with cheesiness on flames.The red and black are simple and clean. There is an often overlooked elegance in simplicity, and you really nailed it.
I also like the inline Atlas motor swap. You don't see that all too often.
Keep up the great build. And I wish you a safe return from your tour across the pond, as I am sure many other members here do as well.
looks more like a 3.5 to me. the 3.7 has an aluminum valve cover, unless someone swapped it over?
3.5/3.7 their basically the exact same motor, I even write 3.5 or 3.7 cause I forget what it is.still a solid build, looking really good
