zaathur151 said:
I am planning on bagging my front end of my s-10 soon and I need to know what's involved for the installation
Heh, what's involved?
cutting - yes
grinding - yes
drilling - yes
wiring - yes
beating, banging, and prying - yes
repeated trips to a store for things that people didn't mention - yes
Any list you will see from people on here will most likely be missing your wires, fuses, quick disconnects, hardware and loctite to mount stuff like the tank(s) and relay(s) and compressor(s), zip ties, rubber grommets, etc ...
Plan every detail to minimize how often you have to stop and run to the store. Luckily I was prepared enough to minimize it to only a couple trips.
Go ahead and get a pickle fork for removing the spindles. Maybe it was just mine, but no beating or banging would remove the lowers. Just be careful with the fork and your dust boots will be fine.
Lastly, depending on what you plan on running ... you might want to consider running a kill switch for the compressor(s). I am running them for mine just to have the control of turning them off manually to keep them from running a long time and getting excessively hot. Here's one of the bagginit.com diagrams that I modified for my particular set up ... if you run kill switches, do it like this. (click for bigger)
