I'm new to the bagging part of modding and the truck that i'm wanting right now is already bagged. Can someone tell me the advantages and disadvantages of having a truck bagged. Will I have to replace the bags every so often if so how much will that run me? Also It has a 5 gallon tank on it,how long will that last me?,thanks
Hoods are overrated
no need to replace the bags unless they're rubbing or dry rotting, i have 65K miles on my bags, and drive it every day
The 5 gallon tank won't have much playtime, but if you're like me and just cruise it around and hit the switches occasionally then it will be fine, i have a 5 gallon at 175 PSI
If you go with good quality bags (Slams, Firestone) you should not have to replace the bags for a long time, unless you rub them and blow a hole on them.
