1 - 20 of 20 Posts
I want to bag my 2000 ext. cab, but i dont know much about it. What can you tell me so i dont look like a moron when i go up to the counter.
thanks:confused:
Premium Member
Well
Well, if it's a good shop, then they shouldnt make you feel like a moron! But, to help you out, to bag your truck you'll need:
-- 4 bags (2500 or 2600 lbs)
-- 2,3,4 link
-- C-notch or step notch (step notch requires cutting hole in bed)
front mounts
-- Rear mounts (unless they are on the link setup, some differ)
-- Airline
-- Valves (depending on what you want to do, F,B,S,S or just F,B you'll either need 4 or 8 valves.
-- Airtank
-- Compressor(s)
-- Misc wiring
-- Fittings
-- Pressure switch for airtank (turns compresser off and on when psi in tank drops below a certain point and raises to a certain point)
-- Shock relocators for front (unless you use Shockwaves which are hella expensive)
I think that covers it. Anyone think of anything I missed?
Premium Member
Not sure on this but.....
I know on some X-cab S-10s to fully lay frame you need a different tranny crossmember, you can get that from Alter Images, they are good people to deal with. Are you doing this yourself or is a shop doing it?
Deadbeat
if you have a shop around that specalizes in suspension work like that they probably wont make you feel like a moron they will be more then willing to tell you what you need and how it works etc etc....alot of these places dont make enuff money to make they're customers feel stupid and get a bad rep.....
yeah i want to get a shop to do it because i dont think i would have the time to do it. yeah the 2000 has a big bump under the tranny so i would have to buy a new crosssmember.....thanks for the help.... one last question, which size valves are ideal.... i want to have fastbags....
amatuer porn star
for fast valves i would go with 3/8" or 1/2" with 1/2" lines
thanks:confused:
How low are you wanting to take it and are you willing to do heavy mods and welding ? If you help me establish a base line of what you are wanting to do with the truck and what the truck will be used for I can help you with the appropriate product.
Tony...
tony, i want to drop it to the ground. i know i have to body drop it becasue i want the doors on the floor. I also would do welding a step notch in i guess. i want it to be really nice show....thanks man
Well if you are going that far with it I would definetly plan on running a tri-angulated four link in it and changing the gas tank to a rear mounted fuel cell. I would also box and smooth the frame that will be visible from inside the bed. In the front you could use something like my coolride front kit along with a set of dropped spindles. In the rear I would definetly use a set of F-9000 like my four link uses in order to get you a good ride and plenty of lift. As for the compressor system........ the sky is the limit.
Tony....
Discussion Starter · #10 ·
thanks alot man, where are you located. i emailed some other company saying that i am willing to drive pretty far for a good price and a good place...one that is trust worthy....so how much can i get that entire system for and do you do it, or do you know someone that could hook me up this summer.....thanks Jeff
Air ride is located in IN but I have dealers all over the place. Where are you located at and I might be able to refer you to a shop in your area.
Tony....
Discussion Starter · #13 ·
I live in South Florida, the Ft. laud area.....i dont mind traveling to a place that you think is better than another one. thanks again
Discussion Starter · #17 ·
Thanks alot, i thinking about going to California customs, i have heard they are good....hope so
later, thanks again
jeff
Bolt-On Body Dropz
hey tony, that air ride in indiana, is the shop in or around Terre Haute, some guy worked at a shop in Terre Haute I think that is probably Air Ride, he bought my brothers old S10 long bed and bagged it, he had it primered orange...
1 - 20 of 20 Posts
