Ok...I want to bag my truck...I want a 1/2'' setup and i want FbSS...and I think I am going to monoleaf it....Tell me all the parts i need...Thanks for your information....
IF anyone needs APC parts....message me I will give you the best deal...I am a apc dealer now....Thanks again
amatuer porn star
4(or 8 depending on what company) valves 1/2"
40' of 1/2" line
1/2" ported bags
fittings
tank
compressor
pressure switch
monster notch
rear brackets
front brackets
teflon tape
toggle switches or a switch box
and i think that should be it.
praise the lower'd
i wouldent suggest useing teflon tape that stuff is schit. use some good thread seal like out of the tube. i use the GM stuff its really good stuff i think its called PTFE. i started to use teflon tape on my setup and that schit leaked in no time but the ptfe is toatly leak free.
just a thought
scott
Afterhours Admin
ive used both, and had no problem with either leaking...now if you are running 1/2" valves, run 3/4" line and ported bags to optimize flow. remember, 1/2" line has an ID of 3/8"
amatuer porn star
avtekk good point on the airline...my mistake.
Bolt-On Body Dropz
in the newest mini truckn, they got a sectoin on tips and tricks or whatever the **** its called, but they give an alternative to teflon tape that they use...id tell u what it is but my brother put the mag somewhere and i dunno where it is
