Im doing a superlift wshbone setup on the back, mainly because Ive never done one on a blazer and wanted to see what itll take. I was going to mount the bags inboard of the frame but didnt like how narrow that made the lower bars. After careful measurements, it was determined that I could easily put them outside the frame without too many mods. This truck will never be running anything bigger than 18s (if that) so the tire hitting the bag isnt as much a concern than if it was on 20s.
First pic is the front hangers I made, they will be gusseted on the bottom when installed as well. They are designed to wrap around the top of the frame and keep the lower bars level to the ground at ride height.
2nd is a pic of the hangers installed as well as the upper bag plate I made. Pretty simple, same wrap around design with extra long gussets. Its made for a Slam RE6 and sits the bag about 1/2" away from the frame. The lowers are SD square unwelded bars fitted with SD Square Threaded Bung kits.
3rd are SD axle tabs with what I made for the shock mounts. Its just an SD universal 4link bar brackets trimmed to fit. They already have 1/2" holes in them so they were perfect for SDs threaded shock studs.
