S10=Honda civic of minis
So I'm needing a spacer plate in the rear to get the most out of my RE-8's. A change in wheels/tires means I'm about 1.75" from fully compressing the bag. I figure a 1.5" spacer would be good. I was thinking using a couple pieces of solid 5" aluminum round bars cut down to 1.5". Then drilling some holes and using that as my spacer.
There shouldn't be a problem using the aluminum, right? How have other people done this?
i need todo the same becasue i did everything for 22's in the back so im only like 3/4 to a inch from fully compressed.you could make a aluminum plate the shape of your lower bag plate and thread it. or just drill wholes were your bags mount and get longer bolts
Afterhours Admin
if you have access to that kind of Al then use it, itll work fine, thats what ART supplies with their roadgrator kits.
Yeah I have good access to the aluminum. Great actually, because nothing beats free. I work in a metal fab. shop.
Anybody know what the thread depth is in the lower bag plate? I can't remember. Just trying to figure what length bolt will work best. I remember it's 3/8"-16 bolts at least. One trip to the hardware store is usually one too many for me.
3/16" plate + 1.5" spacer + hole depth? = bolt I need
