1 - 20 of 29 Posts
"GOT RICE?"
I'm looking into bagging my truck but I have a few ?'s.
1)I live in Canada so the winters here get cold sometimes. Will the cold weather make the bags weak or cause them to crack?
2) How long of a lifespan do these systems last? and what type of maintence do you need to do to them?
3)what would you recomend as a good setup 4 my truck?
Thanks:thumbup:
www.AcrophobiA.net
i dont think the cold has anything to wear the bags.......its hard to say what kind of setp-up to tell you to get when we dont know how fast you want it, how low you want and all that good stuff........also the maintence is like this.....if the job is done right, you shouldnt have that many problems, if you run your compressors all the time, they have a habit of burning out.......just common sense......tell me what kind of setup you want and how much you are looking to spend.....there are a few guys on here who could help you
no fat GUYS, truck will scrape
You could have problems with condensation freezing up in the lines over the winter. The best thing is to use your system as little as possible throughout the winter months to reduce the amount of moisture going through the lines. At the same time, you want to run air through every once and a while to exercise the bags. You're bags should not crack, my b/f leaves his empty all winter with the truck parked and has had no problems with the bags.
The lifespan all depends on how you treat your bags and naturally where you buy them from. Firestone, Easy Street, Air Lift all have good dependable bags. Maintenance is minimal on air systems, you just want to make sure you keep everything clean and it's good to completely empty your tank once a month to get out any built-up condensation.
As far as a good setup for your truck, it all depends on personal preference. I could price out a few setups for you (I'm in Canada as well) and if I can't help you, then [email protected] could also price some stuff out for you.
Let me know what you might be interested in.......... Easy Street Kit (check their website at www.airliftcompany.com) or Air Ride (www.airridetech.com) or mix and match kits. All up to you............... :D You're best bet is to do some research and see what you're interested in.
www.AcrophobiA.net
good call.....but i wouldnt go with east street or air ride cause you dont lay..........i like to lay:evilg:
amatuer porn star
i think the others have said it all. you should also keep your valves clean...get a rebuil kit and clean them every once in a while
yeah, but if you mix and match you can lay................ I'll be getting laid in a few months :bah: :p :D I'm going with Easy Street bags/valves, a Pete & Jakes four link, custom bridge, blah, blah, blah and I'll be laying' . I agree, you can't lay with a kit, but maybe he doesn't wanna lay :eek:
amatuer porn star
i lay ....numerous times each day:thumbup:
STOP!!!!!!!! I don't wanna hear it anymore!!!!!!!!!! I won't be getting laid until MAY!!:cry:
AAAHHHHHHHHHHH!!!!!!!!!:cry: :cry:
Dis Member
Once again...
Not necessarly true...
Re: Once again...
very true i have the air ride tech cool ride front bags and i lay all day long. and airlift(easy street) has a new kit for 210's that lays on 18's up fornt and 20's in the rear.
joshey
www.AcrophobiA.net
thats what i like to here............its about time people can lay with that stuff:thumbup: just as ling as we all are hittin switches and getting layed daily:thumbup:
"GOT RICE?"
Discussion Starter #16
HELP ME GET LAYED
Thanks for the info guys..thats a lot to consider. I want a very reliable system that hasn't been know to have problems. I've never looked into them before so I hoping that you can all help me choose the best out there. I want something fast . I'd be willing to spend @ $4000(canadian funds). I have to get thinner tires first though cause I have 235/275 so I've been told I need 205(215 max). I have 2inch drop spindle and 1 inch drop spring in the front and 3"block 1" leaf drop in the back. AND I AM LOOKING TO LAY THE FRAME(or close to it).I'm looking for a set-up that would require me to cut the least out of my bed. Any suggestions now? Thanks.
amatuer porn star
sonomagril..why arent you getting layed till march?????
i laid before i got on this computer:thumbup:
May is when my truck is going in to do the 4-link and bridge. Money is kinda tight right now.........:cry:
Re: HELP ME GET LAYED
I can have you laying frame for less than $4000 CDN without cutting your bed.
I'll PM you later today.............. :D
For all you US boys, $4000CDN is about $2500US
1 - 20 of 29 Posts
