Canyon Carver
I couldn't find an exact picture of what their s-10 rear kit contains, but looking at there other kits, you will probably have to pull the axles. There is a plate that attaches to the rearend for the calipers to bolt to. The axles run through this plate.
Miles
ya in order to get the drum backing plates off you have to pull the axles....pretty simple though.....just opening the rearend up....removiing the little bar with one bolt, then removing the c-clips and the slide right out
