Mine fit with no issues.
U Joints can be had for $30 on eBay from my experience. Hard part is finding an affordable length of Double D tube. I ended up buying 4 foot or something and shared it around with some friends, but probably ended up in as much as Holley.Sorry for giving credit to the wrong guy. Just happened to see the pic 5 minutes before reading EZA's question, so I copied it here for him to see how close everything is.
I've used an Astro u-joint, but had to reclock the shaft 90° by disassembling the u-joint.
I gather you just bought a u-joint and some DD tube?
Probably fits better than the Holley one. I bought one and had to shorten it 1/2" to get it on. Thought afterwards that I should have just built one. Wouldn't have taken any longer than figuring out what was wrong with the store bought one and modding it. Seems to be a common theme with Holley parts. Only need a bit of work to fit.
When you finally do get it.
I will have when the weather around here breaks and I pull off my cheapazz headers.Anyone got a picture of the Holley steering shaft installed using the Hooker cast manifolds, 2wd? Did a search and found one but not sure if it's 2wd or 4wd.
With the shipping and tax you're talking $45 for a 3" hunk of steel. Add $45 for a ujoint and you've got $90 in it.
So, are you replacing the cheapazz headers with the cast manifolds?I will have when the weather around here breaks and I pull off my cheapazz headers.
