91 S-10 Pickup 4x4
Do they make back spacers for S10s to make the rear backspacing larger? I like my original style rims. If so how much would they cost?
:dunno: You confused me....
You want to increase your backspacing? Adding a spacer will make your backspacking less.
Only way to increase backspacing of your stock rims would be to mill the mounting surface down, not a good idea.
PANFACE
yes they make spacers to fit our trucks, how thick of a spacer do you want? i would kinda stay away from them personally since adding spacers takes away threads that the lug could be using, if your getting a real small spacer, then not that big of a deal, but if your getting a pretty good size one, then i would stay away from that idea. i know if we had them at our work, like if someone wanted us to put them on, we wouldn't do it unless they needed it, like the wheel wasn't gonna go one without it since the wheel would be two wide or something and needed to be pushed out or else it would rub on the fenders while just going straight.
