The Primered Panther
Can anyone tell me what the axle ratio is on a 97 4.3 automatic, 2wd, x-cab, without me having to crawl under there and scrap off the axle to find the number? Just thought i'd ask before I did. Thanks
Say lowered d
i dont think its going to be on the axle housing anywhere, your probably going to have to pop the back cover off and count the teeth on the ring gear and teeth on the pinion gear and divide ring by pinion.
Self Portrait
RPO Codes should tell you
Decode your RPO codes, that's how I found out what mine were.
Rick
'92 S-10 Tahoe 4.3L Bone Stock
2 Da Xtreme
A X L E CO D E S.....................!
There is a Way to find the RaTio
without popping the rear cover and
counting teeth........!
If you think the truck has he original rear end in it......! Go to the Glove box codes and look for the codes like these
GU2 =2.73
GU4 =3.08
GU6 =3.42
:thumbup:
Say lowered d
wow
kewl, i didnt know that!!
