1 - 11 of 11 Posts
=Tenacious D=
I'll be getting a zr2 blazer pretty soon.. I plan to put a lift on it and some 33's a little while after I get it.
why are you spending extra money to get the zr2 when you are just putting another lift on it? You can get a 4wd blazer without the zr2 then put a lift on it and you will end up with the same truck for a hefty amount cheaper. I believe this to be true anyway but correct me if im wrong about the zr2 just being a suspension package.
want my #... 911 beotch!!
correct me if i am wrong but isnt the ZR2 a wide body suspension option?:confused:
=Tenacious D=
Yeah, the zr2 is a wide body suspension package... and because it's already higher than a regualr 4x4 blazer I won't need as big a lift to fit bigger tires (whenever I get to)..
If you are wondering what makes a regular S-10 a RPO ZR2, the following is the list of the factory modifications:
RPO ZR2 only full ladder-type frame with modified suspension mounting points which provide:
100mm wider track (3.9 inches wider than regular S-10)
Three-inch suspension height increase
Enhanced front (7.25" ring gear) and rear (8.5" ring gear) axles w/ 3.73:1 rear-axle ratio
Larger wheel and axle bearings
31 x 10.5R-15 LT/C black wall off-road tires (BFG A/Ts on pickups and BFG Long Trails on BlaZeR2)
46mm gas pressurized Bilstein Monotube shocks
Rear axle track bar (pickups) / rear sway bar (BlaZeR2)
Wheel flares (black on S-10 pickups and BlaZeR2 / body-color on Sonoma pickups)
33mm (early model) / 28mm (late model) front anti-sway bar
Skid plates
For more info go to ZR2.COM
Yamaha Factory Rider
Hey guys. New here and just thought I'd let you know there are other Highrider owners out there. We need to get more people on the site though. You ought to try out zr2.com if you haven't. Lots of smart guys with tons of knowlegde over there.
1 - 11 of 11 Posts
