1 - 14 of 14 Posts
thanks but i need to know what the colors do for each switch like if the green wire is the left front up etc.
i found the one for the 7 switch box. im wondering if the colors are the same on the 9 . then itll be easy to figure out the two other colors.
Oh haha I knew that, but wasnt thinking. Let me try this again..
ok found this on a site.. a 10 wire, but see if they are the same.. usually the sites have a how to on the wiring.. suicidedoors has a how for a 10 switch.. prolly the same as this right here> this is supposed to be an avs wiring>
AVS Wiring:
Pink - Power
White - Front Left Up
Yellow - Front Left Down
Orange - Front Right Up
Red - Front Right Down
Grey - Remote Dump
Green - Rear Left Up
Blue - Rear Left Down
Purple - Rear Right Up
Brown - Rear Right Down
I never had a AVS box so I ddint know haha.
Discussion Starter #9
Our 9 switch boxes do not have colored wires. You wire it through the relay box......
ive been having nothing but problems with the box. i called today. i cut the end off. and im going to wire it using bigger and better relays. i just need to know what color wires do what....
airbagparts.com
Haha, come on guy. You gotta be a little more specific next time. Shoulda put in your first post that you cut the relay box off and needed to know what was hooked to what....
Discussion Starter #12
thought you guys would understand. guess not. its cool. soo do you know what colors do what? what color is ground if theres a ground which one is hot. etc.
1 - 14 of 14 Posts
