Pop A Lockin and droppin
If I do a 3.4 swap into my 91 what class would I be running in.
I turn.
I think any engine swap puts you into street modified. You'd probably normally be in F street prepared or even in one of the stock classes with a first gen where you'd be more competitive. Unfortunately SM will have some nasty cars in it - you likely won't be up there in the standings but it will still be fun.
ugh may have to find a 4.3 then. I aint rading the 2.8. Or maybe ill just v8 and be nuts about it
4 bangin and love it
Not a huge auto crosser, but I do play when ups hold their event. IMO, a v8 is too heavy in a small pickup like that. For anything handling oriented, ou want as close to a 50/50 weight distribution as possible.
I personally would swap to a 4.3, if I was to stay gm. If you have the ability, or can afford to pay to have it done, I would swap to a sr20det or something lightweight but powerful, to stay as competitive as possible.
Swapping to a V8 with aluminum heads, water pump, intake(especially EFI) only ads 70 lbs. Not what I'd consider a lot of weight. Unless you move the entire engine/trans 12-14" back will any engine/trans combination ever approach a 50/50 weight distribution in an S-10 truck. Go have fun with what you have. Change out suspension components; bigger sway bar stiffer springs, lowered, quick ratio steering, wider wheels tires with racing compounds. The likelyhood of any S-10, stock or modified setting "Top time of the day" is pretty remote. You want to be really competitive, buy a fast sedan, pony car or a sports car. Again, go have fun with what you have and make those kind of decisions after you are convinced that Auto Crossing is your cup of tea. Just sayin'.
You can't polish a turd.
Wouldn't a truck with an updated engine swap go to SM2 due to the 2 seater rule?
