Ok ive replace all of these (within the last 2 days, because i got lean fuel code) Oxygen sensor, Caps, Plugs (Gaped at .60 ), wires, EGR Valve, and TPS. TPS was the last to be replaced when I got code 22. I also replaced the MAP sensor like 1-2 years ago. It seems to be missing on 1 cylinder, and i get a sputter noise exhaust side. Also this is a 2.5 in an 85 chevy s-10 pickup.. 2 wheel drive. I have also ran slick 50 Fuel system cleaner thru it. I know that the code 22 is Low voltage at throttle positon sensor OR Fuel cutoff relay circuit open or shorted to ground. What do i need to do now any idea?
:boom:
:wtf:
:boom:
:wtf:
