But this is probably the forum I should have placed this in:
Have a 1999 Chevy S-10 2wd manual. Clutch was working fine, and is a relatively new clutch (i.e. less than 10,000 miles easy). However, it will not now engage. Only thing that I know is that the driver may have downshifted from 3rd down to second, and did not fully disengaged the clutch all the way. Although I wouldn't think one downshift like that would break anything as far at the transmisson/clutch is concerned. I can see the slave cylinder pushing the throw-out bearing into the pressure plate. However, when you let up on the clutch, it does not engage to the flywheel (i.e. with engine running, you can shift through the gears without the clutch but obviously it does not move).
the truck was not used heavily, and possibly very little over the last year.
Any thoughts on why the friction plate will not engage? more importantly, is there any chance of resolving this issue with out dropping the tranny?
thanks in advance,
Andy1dr
thanks in advance,
Andy1dr
