P
phat96
·Guest
How much did it cost u and was it easy to install and did u need a new front grill
Where you get the clip nut things. I am going to do the setup and need them I guess. First I heard of it. Let me know please. Also how do you go about installing the pigtails.AVTekk said:i did them on my truck...
i went to the junkyard and found the correct headlight harnesses and spliced them in. also the sonoma headlights use different mounting points than a sealed beam, so you need some clip nut thingys to go into the square holes in your rad support. haha, hope this helps
