Do not know. IIRC, 2 - or 3 – of the earlier AutoZone failures were at the plastic, side reservoir to aluminum coil section crimp/seal.Any chance of electrolysis in your case?
The thing is, I'm not sure if it was going to stop there. I have tomorrow off so I will find out. I'm crossing my fingers.208 idling isn't anything to worry about.
That was my line of thinking but I wasn't sure if cooling would be sufficient208 is fine as oldeerslayer said. Using water for leak testing is ok. It won't cool as efficiently as a proper mix of coolant and water. Depending on operating conditions, the water might be good enough to operate without overheating.
After testing completes, it can be a bit challenging to get to the correct mix of water and coolant though. When you drain the water, there will always be some remaining in the system. Make sure you account for the water that could not be drained when you're adding coolant/water mix for regular use.....
