99 Blazer
On stuff like that I usually put a nut over it and weld the nut to the broken piece and take it out with a socket or wrench. If it's recessed to far in the hole you will have to drill a hole in the center and use a bolt extractor.
· Registered Hoosier
That is plastic around the brokem turn signal stalk, so welding is out. drill and a screw is easiest. Worst case; tear column down.
