We tried the Auburn rearend in our trucks at work and found them to wear the cones out very quickly. If you dont turn all that much they might last longer as the wear occurs everytime you turn. You also have to run the special additive in the oil. These were behind 2.5 with automatics so I can't see any improvement over the stock Eaton carrier other than the governor parts and clutches wearing out and breakingon the Eaton with replacement parts avail as opposed to the Auburn where the cones and the corresponding cups wear out and no replacement parts
