Just finished checking this on mine and the wires were starting to wear through just like they said.
A/C System - Inoperative
File In Section: 01 - HVAC
Bulletin No.: 00-01-38-008
Date: October, 2000
TECHNICAL
Subject:
A/C Inoperative
(Repair Wires and Reroute Harness)
Models:
2000 Chevrolet and GMC S Truck Models With 2.2L Engine (VIN 4 - RPO LN2)
Built at Shreveport Assembly Plant (Plant Code 8) and Prior to VIN Breakpoint Y8302995
Condition
Some customers may comment on no A/C.
Cause
This condition may be caused by the A/C compressor clutch coil wire being pinched between the coolant outlet pipe and the air cleaner resonator assembly, resulting in damage to the wires.
Correction
Repair any damaged wires. Reroute the A/C compressor clutch coil and engine coolant temperature (ECT) sensor wire harnesses to a new location. Use the procedure listed below.
1. Remove the air cleaner outlet resonator. Refer to the Engine Controls sub-section of the Service Manual for removal procedures.
2. Inspect the harness at the pinched location (1) and repair any damaged wires. Refer to Wiring Repairs in the Wiring Systems sub-section of the Service Manual.
3. Reroute the harness to the new location (2).
^ Disconnect the A/C compressor clutch coil connector.
^ Route the harness over the coolant outlet pipe and run the harness along the back side of the spark plug wire hold down.
^ Reconnect the A/C compressor clutch coil connector.
^ Disconnect the ECT sensor connector.
^ Route the harness underneath the spark plug wires and reconnect the ECT sensor connector.
4. Install the air cleaner outlet resonator. Refer to the Engine Controls sub-section of the Service Manual for installation procedures.
Date: October, 2000
TECHNICAL
Subject:
A/C Inoperative
Models:
Condition
Cause
Correction
