how can it be no offset if it has 4.5bs on a 7" wheel? A 7" wheel with no offset would have a 3.5" bs wouldnt it?4.5 BS , no offset
I copied this and put it in the Backspacing and Offset ..UPDATE Sticky.
Fantastic!I copied this and put it in the Backspacing and Offset ..UPDATE Sticky.
Not totally figured out but Im getting close. Well I was going to powder coat them gloss black but they are too narrow anyway only 15x7. I want 15x8s. I will do some measuring and see exactly what backspacing I need for the 245/60/15 on 15x8 and what size spacers if any I will need to get the look I want, with the tire the same distance to the frame rail as it is now with the 205 on 14x6s, and with the least wear and tear on my bearings, tie rods, ball joints etc. and no rubbing or trimming of sheet metal.Seems you now have this offset/backspacing totally figured out.
BTW, IMHO those swirlie wheels are the ugliest aluminum wheels ever put on an S10 from the factory and if you plan to poke them a couple inches to look cool, they won't.![]()
