Well I fix the problem yesterday. It wasnt the freeze plug behind the starter, it was actually the one behind the motor mount. I removed the starter, removed the bolts that hold the upper motor mount to the lower mount off of both sides. Then i used a piece of a board to cover the head of a hydralic jack and carefully lifted the motor using the oil pan. With the motor lifted, it gave me enough room to get to the three bolts that hold the mount to the engine block. With the upper mount off i decided to go ahead and take the mount off the frame to give me more room to work with. To get the leaky freeze plug out, i ended up punching a hole in it, and then knocking it into the block. Then i used a screwdriver and the hole in the plug to pop it back out. No auto parts store around me had brass freeze plugs, so i had to buy another steel plug. I took some fine sand paper and cleaned the edge of the hole where the freeze plug goes. It was a real pain in the ass to try and install the new plug, considering theres only about four inchs to work with and the plug goes in at an angle. The way i finally got it in was to smear a little grease on the hole and the plug. I found a socket that fits into the cup part of the plug and used a big ass crow bar inside the socket to beat the holy hell out of it. It takes a lot of time to get the freeze plug back in, so be patient and keep beating the sh!t out of it.
Thanks to anyone who gave advice
