I need to put a new head gasket on my girlfriend's truck in the next few days. Coolant is leaking down the side of the block from the back of the head.
Is there a gasket set that you would recomend (head, intake, exhaust, valve cover etc.)? I saw the sticky at the top of page, did anyone figure out the gasket problem?
Is there any common problems I should watch out for?
The truck is '95 2.2L with 112,000 miles. I was planning on pulling the head off with the intake and exhaust manifolds still connected, will that work? I am going to have the head milled and a valve job done on it. Is there anything else I should do while I'm in there (timing chain, etc.)? I'm trying to get this done cheap an right.
Thanks for any help. It looks like you guys have great forum here with a lot of info.
Dustin
Dustin
