i have a problem with my s10 96 the abs light is always on and i dont know whats the problem anyone knows how can i fix it or how can i turn the abs light off
check the fuse under hood, someone could have unplugged it. or your abs sensor went bad, that is behind the tire. my truck was acting like i didn't have brakes cause the sensor went bad, so i just pulled the fuse and now the light is on all the time until i fix the sensors.
do you know where exactly is the fuse? im going to check that cause i havo to take the emission test and they dont want any light on on the dashboard
I alredy find the fuse box but whats the fuse for the abs I just found the one for the brakes
where is the sensor for the abs??
