CREW CAB LONG BED
Hey guys here's my situation 99 s10 4.3 bought it 2 days ago with this code as well as a 420 code and a evap code i put a new gas cap to fix that and cleared the codes I tuned it up and put in a new spider injector it fixed the misfire at idle but now I'm getting a miss at higher rpms and nothing at idle and the code came back for random misfire. Any help would be great I'm thinking the dist gear?
CREW CAB LONG BED
Discussion Starter · #2 ·
Also I replaced all vac line and checked it there's no other vac leaks it sounds like a carb popping at any rpm higher then idle but does smooth out at times very odd
Could very well be the dizzy gear. My random misfire came on at 55mph highway, not hard accellerating but just cruising. I replaced the dizzy gear and that totally killed the misfire code.
BTW, this is what a new gear looks like:
This is what my old gear looked like:
Notice how cut, sharp, and chopped up each of the teeth are.
