Now this.I want to move the C101 plug over to the drivers side and I will also clean/tuck the drooping firewall OEM wiring.
Thanks to you!It looks professional!
The radiator fan wiring looks nice. One suggestion you don't to to mount the relays upside down. They areRad support rework to except 1989 1 3/8" radiator. I used the stock upper mounts in the top of the support after removing the second layer of material. The drivers side was cut for width and then a new patch panel pop riveted back in. The hood bracket is made from two brackets welded together. The condenser is a Ebay and Vintage air U-Ben_Em lines. The wiring harness is actually a harness sold on Ebay that I had to rework. The fans are 2005 Malibu fans that fit great just like @Tranzman said.. I used the top radiator shroud to hold the fans in against the radiator and on the bottom a bracket to hold the fans tight against the radiator. The trans cooler is from a 3500 truck that I flushed I used the stock mounting bracket rework and a bracket from a Cadillac for the bottom portion. View attachment 350037 View attachment 350038 View attachment 350039
Looks great! might I suggest flipping the relay pack, just thing from the standpoint of moisture accumulating.
Why didn't you use weather proof relays? Here's the link to the weather sealed relays I used.Rad support rework to except 1989 1 3/8" radiator. I used the stock upper mounts in the top of the support after removing the second layer of material. The drivers side was cut for width and then a new patch panel pop riveted back in. The hood bracket is made from two brackets welded together. The condenser is a Ebay and Vintage air U-Ben_Em lines. The wiring harness is actually a harness sold on Ebay that I had to rework. The fans are 2005 Malibu fans that fit great just like @Tranzman said.. I used the top radiator shroud to hold the fans in against the radiator and on the bottom a bracket to hold the fans tight against the radiator. The trans cooler is from a 3500 truck that I flushed I used the stock mounting bracket rework and a bracket from a Cadillac for the bottom portion. View attachment 350037 View attachment 350038 View attachment 350039
Okay I see. The company that makes them over in China I'm sure their cost is only a few cents more to use weather proof but they're too much of a penny pincher to do that. But that's just me. being in the car audio and video & security field for the last 35 + years I would spend the extra few pennies then make sure the customer didn't come back. Especially if they live in the snow that salt will eat those relays terminals up in a quickness.I bought the relays from Ebay as a made up set with fan connectors and wires.I didn't relies the relays were not sealed.So yes I could of scrap the relays and bougt new and repined but since I already had the setup I decided to just put them in a sealed box.
Shiny is good.Looking good. I've thought about button head allen bolts to attach the coils and brackets. Stainless if you like shiny.
I would take those freshly painted valve covers and coil brackets and bake them in the oven at 250° for about 2 hours that will harden the paint and make it last longer. Do not go over 250° or it will give the paint a brown tent to it.Had some time on my hands waiting for the engine work so I work over the valve covers and coils brackets. I shaved the two unused lower studs off of the valve covers and removed a lot of metal from the coil brackets.
View attachment 360954 View attachment 360955
