Master Shake
This time though, it's something I want to do with my truck:
The specs: fully boxed framerails, frame holes filled in, 10-point cage, tubular upper shock mounts, dual Bilstein 7100 remote-resevoir shocks per corner, AIM long arm/Fabtech spindle front end, Deaver spring pack in rear with lift shackles/hangers, 4" 'glass cowl hood, custom flared fenders/bedsides, exhaust exiting through notches in rollpan, black headlight bezels and grille, tube steel front bumper with skidplate, Clifford header/Spintech muffler, MSD ignition box and coil, trussed 4wd 10-bolt rearend, 4.56 geared locker. I think that's all of it.
Paint Needing Mofo
hope you got the rebound set up right on them rear shocks... otherwise you're gonna nose in on that jump!! :p :D
looks like a fun project!! good luck with it!
