1 - 20 of 1870 Posts
!! TALK NOW !!
Ok.. I have been working on this b/d since December of 04.. I work on it when i get time between work. school and g/f.. Now school is over I have alot of time.
It is a SFBD.. 3.5" on 255/35/20
New frame from firewall back.. I am stock flooring the bed so I don't have to raise the floor
Here is butt load of pictures for you all
All comments welcome!!
Some pictures are crap.. sry about that..
!! TALK NOW !!
My egr vavle is hitting my firewall right now.. THat is why the cab looks crooked when it is dropped.. I have to order a blockoff plate tuesday from GM
I am keeping my KP 6 link.. just making new uppers
anything ask away or tell me what you think
Afterhours Admin
looks real nice man. i moved it to the BD forum tho. one question: i see you flipped the body mounts on the frame..it looks like they hang lower than the frame, and even if they are even, how will they bolt up?
BUY MY TRUCK PARTS!
hey, this may be a dumb question...but when you were ready to weld this all up, how did you go about it?
obviousl you cut the frame down to match the height, but you then welded along the bottom, and along the top where the new frame and the cut-down sections meet? did you plate over it or...?
I'm just curious...
thanks
!! TALK NOW !!
Discussion Starter · #18 ·
no.. i just fill welded between the old and new frame... then ground it down smooth with the new frame.
hmmm i can't find any good pics to what i am talking about
about the body mounts.. it don't hang lower than the frame.. it just above the frame.. i might have to shorten the rubber bushing that bolts to the bottome some.. but other than that.. it will work
no way to keep this in project section??
!! TALK NOW !!
Discussion Starter · #19 ·
Chappy316 said:
looking sweet man, where are you from exactly??
chappy
right down the road from mike (baggedTB)
I would notch the firewall.. but my cab is on the truck.. and it would be hell getting back there..
Afterhours Admin
i dunno, i guess im missing what you plan on doing with the mounts because the stock pieces stick thru the mount and then a bushing, plate and bolt sit below the bottom. i dont think itll all fit under there without getting dragged on but i havnt seen the finished project yet..
