my girlfriend's amp isnt working. the protect light is on. what could be causing this? i think everything is wired right. any suggestions. thanks in advance.
ecko said:if the board is not shot and there is no short in the line you might be pulling to many ohms from your subs. i do not know what the amp is rated at but if you read the back or the book it will tell you. there is a nother way to see if the bord is shot, unplug the subs and then turn on the deck which should power up the amp, if the amp does not go into pect. mode then there is somthing wrong the you wirning:bash::bash:
