I have a small 176 4 channel amp (6mos old), 2 3way kenwood 6x9's, factory 4's and a small sub. My problem is I recently restored my blazer and tried out the system in my empty interior (It was working fine b4) - It was fine. Now that I have all the seats in and carpet etc. and the rear channels do not work. I did some wiring tests and found that the problem is within the amp. I took it all apart and no signs of burning or loose connectors - any ideas?
The Original A D M I N
could be anything. could be a resistor on the board. i would send the amp to the manufacturer if it is under waranty!
Check for hairline fractures of the solder connections. You might have to move the perts around to find them... I got a free Soundstream amp because the guy thought it was fried :D
A bit of solder here & there....
