Good ole' Chilton told me that in order to replace the bushings on the sway bar (on an '88 blazer), you just un-bolt, replace, and bolt again. Well, silly me, I did what it said, but even my superhuman strength couldn't get the **** bar to sit where it needs to be on the lower A-arm to bolt it in. It wants to bend so much that it will not go where it should go. It was fine before, and I haven't had an accident that would cause it to be bent wrong. Has anyone else done this, and what it the trick to putting it back on?
