Does anyone know where I can find an aluminum radiator for the 2.2. So far the only ones I have found are for the 4.3 or the v8 conversion. I've tried searching on here but I cannot seem to find any definitive answer on it.
time to get cereal
Rockauto used to have one. I'm putting a Mishimoto Cobalt SS radiator in mine. Not quite a bolt-in affair though.
91 base=driver, 94 mid engine=build
Whats wrong with running a aluminum one for a 4.3 or v8(corvette) radiatior?
I paid something around $220 for some foreign made all aluminum v8 swap(corvette) radiatior with a aluminum shroud and 2 no name 12" fans that will get swapped out later.
My radiatior is back where the spare tire was previously because I will be running a 5.3 hard and wanted the additional coolant and weight distributions.
But I used the old stock 2.2 radiatior for mockup. The all aluminum v8 conversion one is just a bit thicker.
As long as your thermostat and fan clutch(if equiped) is working a larger radiatior is not going to hurt anything. You may need to trim a bit in spots depending on the radiatior used.
If you want in a direct bolt in rock has many good radiatiors with plastic sides that can be shipped to your door for around $120ish.
Sorry about that. Turns out I used an old 2.5 radiatior for mockup.
I understand wanting to run all aluminum those plastic necks like to crack.
But maybe you can play with the hose routing etc. As a 2.2 s10 all aluminum one is a bit of a nitch.
Wall Building Gas Composite material Wood
