1 - 13 of 13 Posts
Wang!
driveability might suffer, depending on how light it is compared to a stock wheel. Will make for a faster revving motor that will drop RPM quicker between shifts and may cause a bucking condition when starting from a stop, but most likely its not that light and it would work fine.
Ahhhhhhhhh Satisfying!!!
Yeah, since you're in their replacing the clutch, pressure plate, throwout bearing and everything else anyways. It'll make starting from a stop a little bit fun since you have to rev it higher, but the motor will just spin that much faster anyways. It'll make your truck more fun to drive, but you'll probably lose a little bit of lowend driveability.....
Caleb
same starter.....and the flywheel is the same stock part number.
Caleb
right, its gotta be the same year cavvy, but it'll work.
caleb
1 - 13 of 13 Posts
