2000 s10..2.2.. alt is disharging when running and has a burnt wire smell in cab after sitting over nite.. not sure whats wrong or where its comin from.. im not a electrical person at all
Hoosier Rick 5014 posts · Joined 2010 Add to quote Only show this user #2 · May 9, 2021 I would pull the alt and have it tested at someplace like OReilly.
chevymec 3076 posts · Joined 2010 Add to quote Only show this user #3 · May 9, 2021 I would disconnect the battery cables when not in use until you can get it checked. Are the cables loose?
TomA 667 posts · Joined 2017 Add to quote Only show this user #4 · May 9, 2021 Pull fuses one at a time until the draw goes away. That will isolate it to a particular circuit, at least. And definitely have the alternator checked.
vwbugg2275 Discussion starter 2 posts · Joined 2021 Add to quote Only show this user #5 · May 10, 2021 its fixed
Hoosier Rick 5014 posts · Joined 2010 Add to quote Only show this user #6 · May 10, 2021 Please share the fix.
