I recently bought an 83 s10 swapped with a throttle body 350. But they changed the throttle body out to carburated. The wires were a mess when I got it but we went through got rid of a bunch of unneeded b.s. Now I've got one problem. For the life of me I cant get the altenator to charge. I've put 3 used alternators on and a brand new one. The brand new one is on now. After removing all the wires from the altenator and testing straight off the hot post of the alternator I get .83 v. When testing with everything hooked up I'm staying at around 11.9 v. Now I'm lost on what could be causing this problem. I am to understand that I should be seeing around 13.5 v when running. I see about 11.02v with headlights on. Please ask any questions and I'll do my best to answer quickly so I can get this problem taken care of. I'm new to the v8 swapped s10 stuff but I do know a bit about mechanical work.
94 4x4,01 Blazer
2001 Blazer 4dr 4wd LT
to eliminate the first issue- take alt to parts store and have them test it. if it tests good-more than 11.9- look at your pulley sizes on engine.
Do you think the pulleys on the engine might not be turning the altenator quickly enough to produce charge?
94 4x4,01 Blazer
could be- have it tested first- you might have underdrive pulleys as a horsepower gain - does happen .
Is the alternator an 83 10 or 12 SI or a later CS? You can tell by the plug on the back. An SI has a 2 wire flat connector for the sensor and idiot light. The CS has a newer style connector that can handle 4 pins, but usually only the same 2 are connected.
The SI needs the #1 pin (the left one) connected thru an idiot light to work and the other small needs to be connected to the battery. Usually at a junction block or some other B+ red wire as far from the battery as possible to sense how much current the electrical system needs.
A CS is wired the same but the wires are L and S (light and sensor) which are the 2nd from the left and the right one.
If these aren't connected it won't charge properly.
342274
Discussion Starter #7 (Edited by Moderator)
The alternator is for a 95 model. These photos seem to be according to your response a CS. Thank you.
342278
342280
Appears to me that the brown one is correct, but the red one is not there.
Usually there is a pink wire only if there is no alternator light. The larger S terminal is the sense wire which determines the alternators output based on what the voltage is in the battery circuit. That's why it is a red wire. Because it's part of the B+ wiring system. (Red also means always hot)
