So I don’t know if this is a case of previous owner neglect or if this thing is inherently a POS, but heres all the problems my truck has. It is a 2003 blazer with the 4.3, rwd.
-makes a really crappy rattling sound in the 1100-2000 rpm range
-oil seeps out of near every gasket even though i changed them all (Ill blame myself for this one though) but interestingly never puddles underneath
-the harmonic balancer and crank pulley wobble very noticeably. I’ve read mixed things about this, Im inclined to believe the crankshaft is bent but how does such a thing even happen? It has good oil pressure, 55 psi on a cold start and 40 psi at hot idle
-coolant becomes contaminated with some strange oily substance. Idk if its oil or what but Ive flushed it a couple times now and it still does it, although a lot less.
-one or all wheels has a loud, cyclic clicking sound that increases with speed
-a lot of play in the steering, alignment is off, suspension makes a loud popping sound on tight turns
No check engine light, though and it runs great on the freeway, but taking off from a dead stop, it rattles like a maraca then stops once it hits 2k rpm and the harmonic balancer wobbles even after putting a new one. These are my biggest concerns. Is there anything I can do to address all these issues short of a full engine rebuild? Ive replaced everything bolted to the engine at this point, it’s ridiculous. The rattle seems to improve for a while after replacing certain parts then comes right back. Tired of it.
if i had the time and money Id tear out this POS motor and put in a 6.0 and 6l80e.
