bumper and corner lights are always out. Courtesy lights dont come on and interior lights have no power when the doors are open.
Could this be my headlight switch?
btw my door sensor thingies work fine. (buzzer goes off and on when i close open the door)
It's probably the switch. You can check by using a jumper wire with alligator clips. Take off the two screws below your headlight switch and tilt out the switches. The bottom one is the one. there should be 4 wires going into the back of a white plastic plug. Open the back of the plug and jump the red wire to the brown and then the orange. You should have tailights and bumper light when you hit the brown wire with power and dash lights and interior when you bridge to the orange. Good luck. I can go over it in more detail if you need more help. Peace.
