Status
Not open for further replies.
1 - 20 of 20 Posts
The Dave Inc.
Last Updated 9/28/2012
PM, contact
What?, for anything to add, update, change, anything.
Performance Parts threads!
Performance Parts List! - http://www.s10forum.com/forum/showthread.php?t=88841
Intake(Brand, eBay, Homemade, Dyno) http://www.s10forum.com/forum/f105/intake-brand-ebay-homemade-dyno-325694/#post4676743
Inline Fuel Pump Install http://www.s10forum.com/forum/f105/msd-fuel-pump-installation-303943/
HP Tuner for 97-01 http://www.s10forum.com/forum/showthread.php?t=239446
Tachometer Installation http://www.s10forum.com/forum/showthread.php?t=50487
Stock Gauge Swap http://www.s10forum.com/forum/f105/stock-tach-286311/
98-03 56mm TB Mod http://www.s10forum.com/forum/showthread.php?t=93993
Performance Pullies http://www.s10forum.com/forum/f105/how-to-install-performace-pulleys-304284/
ASP Pullies http://www.s10forum.com/forum/f105/2-2-underdrive-pulleys-installed-and-dyno-results-412780/
E-Fan Mod http://www.s10forum.com/forum/showthread.php?t=116754
Al's or OBX Header Install http://www.s10forum.com/forum/f105/how-to-2-2-header-install-422360/
Roller Rockers http://www.s10forum.com/forum/showthread.php?t=234639
Cavalier Intake Manifold Swap http://www.s10forum.com/forum/f105/cavalier-intake-swap-how-to-318637/#post4540272
Automatic Tranmission Mod http://www.s10forum.com/forum/showthread.php?t=272615
ECOTEC Engine Swap HOW-TO http://www.s10forum.com/forum/f105/the-ecotec-swap-how-to-56k-warning-494496/
Basic Mechanical Threads!
Head Gasket Replacement http://www.s10forum.com/forum/f105/how-to-2-2l-head-gasket-job-tips-steps-465392/
IAC Valve Replacement http://www.s10forum.com/forum/f105/how-to-new-iac-valve-replacement-397867/
Timing Chain Replacement http://www.s10forum.com/forum/f105/how-to-replace-timing-chain-parts-368017/
Serpertine Belt Replacement http://www.s10forum.com/forum/f105/howto-serpintine-belt-removal-instalation-355094/
Air Pump Replacement http://www.s10forum.com/forum/showthread.php?p=3547675#post3547675
Alternator Replacement http://www.s10forum.com/forum/showthread.php?p=3220755#post3220755
Clutch Replacement http://www.s10forum.com/forum/showthread.php?t=178334
98+ Coil Pack Replacement http://www.s10forum.com/forum/f105/1998-ignition-coil-changeout-writeup-pics-498253/
Flex Fuel sensor http://www.s10forum.com/forum/showthread.php?t=200562
Fuel Filter Replacement http://www.s10forum.com/forum/f105/how-to-replace-fuel-filter-437201/
Fuel Gauge Reading Problem http://www.s10forum.com/forum/f105/if-you-have-a-broken-gas-guage-read-this-347914/
Fuel Injector Swap/Replacement 98+ http://www.s10forum.com/forum/f105/how-to-injector-swap-for-98-a-371133/#goto_threadtools
Governor/Speed Limiter Removal http://www.s10forum.com/forum/showthread.php?p=3220727#post3220727
Head Gasket Replacement http://www.s10forum.com/forum/showthread.php?t=238583
Header glowing problem http://www.s10forum.com/forum/showthread.php?t=144532
Oil Cooler http://www.s10forum.com/forum/f105/oil-cooler-130715/
94-97 A/C Upgrade http://www.s10forum.com/forum/f105/...-your-95-97-2-2-ac-system-473432/#post7729967
94+ Cruise Control Install http://www.s10forum.com/forum/f105/how-to-cruise-control-install-497908/
Information of 2.2
Detailed Info of 94-03 2.2L
http://www.s10forum.com/forum/f105/2-2-growing-pains-321784/
Timing Chain without Tensioner
http://www.s10forum.com/forum/f105/new-timing-chain-without-tensioner-502857/
Stock Camshaft Specs
http://www.s10forum.com/forum/f105/gm-ln2-2-2l-2200-camshaft-guide-481955/
Valve Springs Specs
http://www.s10forum.com/forum/f105/gm-ln2-2-2l-2200-valve-spring-spec-list-446053/
Super Moderator
Re: ALL 2.2 Performance Info; How-To's CLICK ME!!!
Where can i find torque specifications so i can put my new head gasket on, and get the engine back together?
Super Moderator
Hayne's/Chilton Manual Book.
Any Tips on insulating an aluminum cold air intake? I want to try thermo tec header tape maybe it will cool down the intake.
Hi, I'm a new user and am very glad I found this site. I picked up a 98 standard cab last year with around 140k and have been driving it with regular maintence ( so far ive done ujoints, starter, plugs and wires, upgraded radio, door pins, and so on.) Im looking forward to doing the big 3, and running the efan, upgraded pulleys, 56mm tb (im gonna try to find one off a 95 buick to stay with the how to thread.) cold air intake and header. I was wondering if anyone have done all these mods (im sure there are plenty) and could post some horsepower and mpg gains, and anything else I need to know. Thanks alot
Does anybody know what to tune on an efi live tun i have a 2000 ext cab stepside with a header,exhaust,gauges,and an cold air intake with 36,000 miles and have tried messing around with my stock tune but i dont know what to modify every time i try a new tune it makes it worse what do i do?
This is what Caviler timing cover (left) looks like vs. a 99 2.2 s10 (right). During a engine replacement both the timing cover and oil pan will need to be switched. Have a nice day and hope this helps.
i am trying to find the stock specs on a 99 head. bought a remaned head and need it shaved down to 30 thoasandths but its already been shaved some and i need to know what stock is so i can figure out how much more i need to mill it. some help would be great. thanks
Hello I recently just bought a 97 gmc sonoma 2.2l and I love it it there is one thing whenever I go to try to accelerate the engine seems to rev up really high this Is only when I give it a lot of gas I know it's not going to be super fast but i believe something is wrong it's like the trangmissin just quits any ideas on what it might be .?
OK I hope somebody can help me. I blew the motor in my 97 gmc sonoma 2.2l and I bought another motor just like it out of a 94 model s10. The problem I have is the crank position sensor , I cant seem to find it on this motor its not in the location of the 97? Can anyone tell me were the sensor may be and can I run my plug on my harness to it? Thank you
2.2 Extremist
That it will not^
It's been said time and time again. You'll need to find a 97 2.2.
You MAY be able to get a 96 to work but I can't remember exactly what was different.
I'm a bit rusty on my 2.2 info.
A 94-95 2.2 will not/can not ever work.
Same with a 98-03.
I’m looking for a part it is the bushing that Goes in the transmission tail housing can’t find the bushing anywhere can you help please
1 - 20 of 20 Posts
Status
