241 - 259 of 259 Posts
1995 S10 2.2 liter 5 Speed 2wd RCSB
Ouch!, Glad it didn't damage anything else.
Discussion Starter · #243 ·
yes, i didnt hear anything on the news, so, im glad noone else or other proprty was damaged. those tri-bars have to weight a good pound at least of billet aluminum, at 75 mph has got to be a helluva site
Discussion Starter · #244 ·
It’s always something…🙄
so for the past few weeks i have been having an intermittent no start conmdtion.
thought maybe the fuel pump was going out.
tonight we poulled the bed, and i had no power at the pump.
i started tracing the fuel pump power wire back to the fuse box and it seemed fine. Tested fuse and realy, and both seemed fine.
Removed relay and moved it into another spot and was had power at the pump, and was able to start the truck.
Im thinking either i have a couple bad realys that i have been playing russian roulette with, or i have a bad connection in the fuse box bewteen the relay and fuse.
But, im glad we pulled the bed, as i need to do some work under there that i couldnt do from underneath.
I need a wiring diagram for the stock 1995 fuel pump module. there are two plugs on it, and i need to know what colors are what for those plugs.
· B4U Task Force
@oldeerslayer might have diagrams..
· Premium Member
Check with deathphoenix99. He is back active on here and knows his wiring inside and out.
· Premium Member
What was your mos or what did you do in the military? I'm in Killeen and get to take care of some cool og dudes from all over the country. Crazy ass stories.
Watcha improving now?
Discussion Starter · #253 ·
pulled the front fenders to cut off the inner lip and tig weld in a 3/16 round piece to build strenght back into the fender.
Im slowly working on building inner fenders, and the other trim pieces under hood.
Crankset Wheel Automotive tire Tire Bicycle part
Hood Automotive tire Motor vehicle Tread Wood
Tire Hood Automotive tire Motor vehicle Wood
Awesome! Fabricating is fun... Not that I do it, lol but I run ideas through my mind all the time and try to "tinker" to get the results I had come up with! I am not a "good" welder but I am patiently learning.
I would like to cut my inner fenders back some, I have not worked it all out yet but I did snag one from pull a part to play with!
· Premium Member
Did you form the piece first or just tack and bend it around the curve?
Discussion Starter · #256 ·
Awesome! Fabricating is fun... I did snag one from pull a part to play with!
yessir, have fun with it. If you mess it up, get another one. practice and have fun with it
its not a big area, hand bent it into shape, then some tacks, followed by a few passes
· Premium Member
Def nails the Alice persona. Hah.
