pwnt
I just got home from the store, and when I pushed the button to turn on the alarm, I don't get sound but the lights come on. I opened the door and the alarm didn't go off, so it isn't turning it on. I flipped the switch a lot of times to reset it, but no luck. The door poppers work, but the alarm isn't. It's an Alpine alarm. Does anyone know what to look for?
Thanks
Xtreme Dreams..
If you have the instructions to your alarm, The book will tell you how to remove it VIA the control pad, if not you need the find the switch, it should be a little button somewhere on your driver side under the dash. Hold it in and turn you key to the acc, don't start the truck and it should go off, But first to see if valet mode is on, see if you indicator light is solid red... If it is your in Valet mode.
didnt you just get it installed at a store? take it back to them and have them show you how to work it, or if it not that easy, have them fix it!
