I just recently had my front bagged with the help of southern,
now im have ing a small problem with airing out.
when i fill my tanks then drop it , by the time i come out in the morning to go to work my shit is empty, it has done this a few times but only if it is over night( takes a long time to air out of the tank) any suggestions
erik
OH YEAH....THANKS SOUTHERN REMEMBER THE CHICK AT AUTOZONE
do you have a water trap?? Thats where my leak was. Just spray soap water on on your fittings around the tank, you will eventually find the leak.
SPRAYED THE SHIT OUT OF IT WITH SOAP WATER couldnt find it
Re: Re: airing out problem
bzzzt said:
i think i found your problem........ :D
:lol:
Umm.... make sure you don't have a faulty check valve. Dunno how to check, but it could be at fault.
if you are using PTC fittings, make sure the line is straight going into them and the ends of the line have no more than a 15 degree angle on the cut.
