didnt know where to put this but i have a 4.3 so i put it here. When i use my AC then i park in my garage there is a little puddle of something underneath where abouts my AC is. I t looks like water but i have no clue what AC fluid looks like so im not sure. My AC still blows ice cold. Could this just be condensation melting off or do i have a leak?? Any help will be appreciated.
ya it does evaporate but it takes alot longer than water considering how hot it is out . But then again it is in the garage. But does this happen to anyone else?? I have only noticed it the last 2 days which have been like 40 degrees celcius.
its water, actually moisture removed from the air that enters your refrig. systems evaporator coils, hence the name air conditioning... the condensation is normal - i'd be worried if your a/c system does not drain water - hope this helps
ok the little puddle from yesterday is still mostly there. It has evaporated a little bit but most is still there. The liquid has no smell and is pretty much clear like water. But when i put it on my fingers it feels a bit oily. Any insight??
355 member
:haha:
a/c fluid. it's condensation brother
