1 - 11 of 11 Posts
18 Inch Seamless Air Tank
http://store.gaugemagazine.com/18-inch-seamless-air-tank.aspx
These seamless aluminum air tanks have revolutionized the regular welded air tank construction.
The new style of technology to create non-welded tanks are amazing.
The metal spinning process have allowed Specialty Suspension to create these tanks from a single piece of extruded aluminum tube.
The Flow Forming Technology used on the port holes re-forms the base metal inward into the tank to give a superior surface area for threading.
The standard mounting hardware that's included with these tanks give an endless range of mounting positions and angles.
Product Specifications
Length
18"
Diameter
6.625"
Ports
(4) 3/8" Ports
(1) 1/4" Port
Pressure Rating
200 PSI Rated
Industry Labeled Size
3 Gallons
Actual Volume
2.2 Gallons
We have these air tanks in stock and ready to ship!! Order online or call into the office!! 317-856-1810
2 Firestone 5 Gallon 10 Port Steel Air Tanks
http://store.gaugemagazine.com/firestone-5-gallon-10-port-steel-air-tank-1.aspx
High Quality 5 Gallon Air Tank. 10 Ports: (4) 3/8" Ports on the face, (1) 3/8" port and (1) 1/4" port on each end, (1) 1/4" port on the bottom, and (1) 1/8" port on one endDimensions: 34" Long x 7" DiameterManufactured to SAE J10 Specifications.Pressure tested to twice working pressure (150 PSI working pressure)Baked black enamel on inside / outside to prevent corrosion.Firestone air tanks are designed for both industrial and automotive applications.
We have these air tanks in stock and they're ready to ship!! 317-856-1810
2 Gallon Black Aluminum Tank With 6 Ports
http://store.gaugemagazine.com/2-gallon-black-aluminum-tank-with-6-ports.aspx
Limited on space? This tank is your solution! Very low-profile at only 4" tall.
Ideal mounting locations are under the cab behind the rocker panels, behind bumpers, stacked and hidden behind a panel in your trunk, etc.
This tank does not include mounting brackets, so you can come up with your own crazy mounting scheme, or purchase our optional stainless steel mounting brackets which can be mounted to the floor of your cab or side of your frame.
Product Features:
Measures 4"x37"
(4) 1/4" Ports, (2) 1/2" Ports
Color: Black
We have these air tanks in stock and they are ready to ship out!! Order online or call into the office!! 317-856-1810
http://store.gaugemagazine.com/images/products/detail/TK2ALUM_BK01.jpg
2 Gallon Silver Aluminum Tank With 6 Ports
http://store.gaugemagazine.com/2-gallon-silver-aluminum-tank-with-6-ports.aspx
Measures 4"x37"
Color: Silver
Discussion Starter #8
24 Inch Seamless Air Tank
http://store.gaugemagazine.com/24-inch-seamless-air-tank.aspx
Length
24"
Diameter
6.625"
Ports
(4) 3/8" Ports
(1) 1/4" Port
Pressure Rating
200 PSI Rated
4 Gallons
Actual Volume
3 Gallons
Discussion Starter #9
28 Inch Seamless Air Tank
http://store.gaugemagazine.com/28-inch-seamless-air-tank.aspx
Length
28"
Diameter
6.625"
Ports
(4) 3/8" Ports
(1) 1/4" Port
Pressure Rating
200 PSI Rated
5 Gallons
Actual Volume
3.5 Gallons
We have these air tanks in stock and they are ready to ship out to you!! Order online or call into the office!! 317-856-1810
Discussion Starter #11
3 Gallon Aluminum Tank Gloss Black Powder Coated
http://store.gaugemagazine.com/3-gallon-aluminum-tank-gloss-black-powder-coated.aspx
If you are looking for a stylish Accuair tank, this gloss black powder coated 3 gallon tank is the answer.
Features
Aluminum Air Tanks are lightweights and corrosion resistant.
Extruded and 100% TIG Welded for maximum quality.
High Pressure Rated for operation up to 200 psi. Multiple Ports for maximum flow (plug the extra inlet if not required).
Compact Layout for minimal space usage.
100% Weather Resistant for harsh under vehicle environments.
We have these air tanks in stock and ready to roll!! Order online or call into the office!! 317-856-1810
http://store.gaugemagazine.com/images/products/detail/3gallonaccuairblacktank.jpg
1 - 11 of 11 Posts
