1 - 11 of 11 Posts
what are the pros and cons to this setup i'm deciding on what to do to my truck and what fits my application it'll be a sunday driver and going to and from shows. i just want front and back to be able to lay out at shows nothing to fancy.
to lay out with a air of leaf is gonna require dearching a mono leaf and most likely a block on top of that . doing this will basically increase wheel hop and leaf spring twist dramatically . in most cases where a air over leaf is used its someone wanting a extra towing capacity or someone thats not in for the BIG drop . yes it is possible but the wear and tear will in the long run cost you more than the 4 link would now . GOOD LUCK
what exactly is the difference between a 2,3 or 4 link and thank all you guys in advance
Vandelay Industries
i would recommend reading up in the forums just do searches for 2 link , 3 link and 4 link. theres tons of info on here about them. from my own experience i have a 3 link from suicide doors and i love it.
Discussion Starter #9
does it matter what size wheel you run and the different link you go with.
1 - 11 of 11 Posts
