can you lay frame with an ART air over leaf, monoleafs, and a 4 inch block, 2.25 bolt in notch and 205/60/15s? and how fast would the 1/4" ports be on the f9000 bags with 1/2" ups 3/8s dumps and 5/8s line?
Yes you are right. It is removing all of the leafs but one. And yes you no longer can carry a paylod with the leafs alone. That is where the airshocks or airbags come in to play. They handle the weight. But would I try to carry a heavy load with this setup. No way. I would not try this on a Blazer either.smullen said:I keep hearing people say Monoleafed...
Is this a legitimate product that somsone sells? it sounds like a hack of an existing product...
I've only seen like Belltech 3" Drop Leafs + 3" Drop Blocks..
It sounds like you removing all the leaves (if that the right term) would totally reduce the load capacity of the spring...
Could be an issue as I will have a lot of weight in the back of my Blazer...
Both of these trucks are 95 models. They have the weaker leaf setup in the back. So they can lay out with stock monoleaf plus 4 inch block. With the newer and stiffer leaf packs(98+), to lay out you must dearch the leaf. On the newer stiffer leafs you will be about 1 inch from laying without getting them dearched. But they carry no weith either. So I have seen the stock monoleafs not dearched still lay out when you put any significant amount of weight in the bed.SlammedDime said:If the leafs are dearched, then I don't see a problem with laying, now if you use stock leafs, broken down to a mono, then you *might* not lay, but with a dearched leaf, you should lay with a 4" block.
