Wondering on what people are running and experiences using different brands of manifolds. Accuair slam evolve ect. Everything I find is from 2008 and so I'm sure they have changed a bit since then. Seems like a cleaner easier set up than running 8 smc valves. Most im seing run 1/4 firrings to 3/8 line so speed is going to be slowed down.. would like to run 1/2 lines with 3/8 fittings .I'm wanting to run 4 corners probably a 9 switch controller. So just looking for people's experiences before I decide on which to buy. Have ss7 bags front and back tia
manifolds are easy to hook up and hide. Brand is like nike or ford, you buy what you like.
8 smc valves.
single valves are great in my eyes and they have their place, so do manifolds.
its not 1999 anymore, no one likes fast bags.
then do just that. But why 3/8 fittings? ½ line get ½ fittings
you can do that, but again, its not 1999 anymore, and unless you have a impala on hydraulics, that switch box just gets in the way and you cant use 75% of the functions on it, so its really just a pia.
What are you really wanting? Since you didn’t give any info into what you are after.
For example, 200psi with ½ lines and ½ fittings with ½ SMC valves located by each bag will be able to hop the front of an s10 a few inches off the ground.
So if you give more information, we can help out more.
Me, personally ill never run a ½ line airbag anything ever again. I’m all for that ¼ inch, ball valve life.
Plus the bigger the line, the harder to route. Use 1/8” gauge line.
Any manifold and Avs switch box And harness is super use friendly and neat but a month after u finish u won’t use but 3 switches on the regular.
individual valves For all four corners can be made to look almost as neat but it’s way more work.
accuair is coming back but with the original manifold, they aren’t gonna make themost recent cooler looking version so if I were u, I’d buy a vu4 if going accuair, that way u can always get parts.
